shovelhead frame identification help
my son bought me this frame for fathers day to start a long wanted shovelhead project unfortunately he got it with no paperwork i need help figuring out any info about this frame like, what year, model can the casting numbers mean anything no vin block but stamped steering stem and the most peculiar is a Maltese cross under the steering neck. The state of Texas has told me its not on stolen file but cant find any record of this id number being registered or title after 1987 tank tabs were cut off and there's no markings on the upper motor mount. Thanks
trans mount
trans mount
It looks like a mid/later-75 to 76 model frame.
On the steering head, forging number 47591-35A was introduced around late-68 and it was used for some time. On the other side the forging die number looks like 58. It’s followed by a forging hallmark which may be DIF (in a square) representing Interstate Drop Forge, maker of the steering head.
I don’t know what the cross indicates but I’ve seen similar markings before on one H-D part or another. It may have been stamped by an inspector?
Upper rear forging number 47645-65-Y was introduced around 73.
Lower left rear forging number 47654-73 and lower R-H rear forging number 47652-73 were both introduced about mid-73. Notice at the back of these forgings there are single-hole blocks to accommodate passenger footpegs. These blocks help indicate the frame is somewhere from about mid/later-75 to 76 inclusive.
In your other thread it was said that the footboard tab says it was an FL frame. But I disagree because I have examples of that footboard tab on 75–76 Super Glide frames as well as on FL frames.
Are you sure there are no markings on the upper motor mount? What side were you looking at? For a mid/later-75–76 model frame I’d expect a date code on the left side of that mount in the area highlighted below. If nothing there, please check further down that mount, near the slot.
The swingarm is 73 or later due to it being square-tubed. (Big Twins 58–72 had a round-tube swingarm.)
Eric
Eric
The following 2 users liked this post by Speeding Big Twin:
Architect (07-11-2022),
eighteight (12-19-2023)
But as I informed you in the last thread on this the neck numbers boss has been screwed with and the bikes been issued what's called a blue tag or a state supplied ID number. You should do the dance with the local cops, highway patrol or whatever agency your state has for ID inspections to be sure you CAN use the frame before you get busy spending another dime on it.
Ignore this advice at your own peril my friend. They tend to get kinda wound up about this stuff depending on the local laws you have.
with a starte issued tag it was possibally a stolen & recovered bike at one time & will never be worth as much to a buyer as one with good factory numbers,
I wouldnt spend a fortune on it unless I planned to keep it & as Twizted says, do the dance with the local DMV/Cops before spending any cash on it,
smitty901 (07-14-2022)
Eric
AJSHOVEL (07-11-2022)
Wrong, floorboards take two mounts per side, the rears of both sides are on the frame.
Received 5,463 Likes
Unless you are getting the frame for free, probably not worth the effort as Twisted has pointed out. Mid to late 70's frames are $1500, go find one that has not been hacked and has good usable numbers.
Even for free you probably will be upside down by the time you get her welded up, never mind DMV.
The following 2 users liked this post by AJSHOVEL:
Racepres (07-11-2022),
Speeding Big Twin (07-12-2022)
