CV Carb Adaptor
CV Carb Adaptor
I had a few CV carbs around and I purchased an adapter to mate a CV carb to a Shovel intake manifold.
I found that there are two basic types of carb adapter..one is all metal that is supposedly a press fit to the CV carb.
The second one is cheaper and is rubber with a hose clamp.
I found that the rubber adapter did not fit the CV carb very well....very sloppy fit for sure.
I puzzled over it a bit, and grabbed a twin cam carb manifold I had, and removed the rubber seal ring that attaches the CV carb to the TC intake manifold.
Of course the TC seal ring fit the CV carb perfectly, but the TC manifold side, was too big to slide over the new Shovelhead carb adapter
Since theTC seal ring has a larger diameter TC manifold side, and a smaller diameterCV carb side, I simply sliced the bigger TC manifold side off the rubber....now I had a seal ring that fit over the cv carb outlet, as originally designed........ and now the CV/shovel carb adapter, slid perfectly over this cutoff rubber seal, eliminating the mismatch perfectly.
I hope this is not too confusing!!
https://www.ebay.com/itm/40365492325...oAAOSwoWxifTUn
https://www.ebay.com/itm/23360461138...kAAOSwq3he0rtz
https://www.ebay.com/itm/16381961495...YAAOSwXoZdVRG7
True... But... I detest the Rubber one...If you want to know if the Carb is Supported properly... Put it on a RubberGlide... it Will Tell The Tale...
TwiZted Biker (07-01-2022)
Yet the Flange should actually be Impossible to remove from the Carb on the Solid/Press-on ones... If done Properly..
