Shovel Rocker Box
![Old](https://www.hdforums.com/forum/images/kirsch/statusicon/post_old.gif)
04-01-2021, 05:48 PM
Shovel Rocker Box
Looking for torque specs for Shovel rocker box bolts...none in manual...Tia...
04-01-2021, 07:33 PM
Depends on gaskets used paper or tin
04-01-2021, 08:35 PM
04-01-2021, 09:05 PM
15 lbs should do it - THE STUD STRETCHES be care full thinking its not tight enough
04-04-2021, 04:59 PM
Tighten in a criss-cross pattern 4 sections total, 2 on each cover. Re-tighten after a few miles, make sure surface is flat before you start anything.
04-04-2021, 05:31 PM
Originally Posted by
cravinbob
the picture of the bike its an FLH with 5 gallon gas tanks - you cant get to almost all the nuts to re tighten unless you remove both fuel tanks
is that what your suggesting or only tightening just 2 or the nuts
jarley77
12-22-2019 06:45 PM
ihjonny
07-28-2013 03:32 AM
pesnemesis
General Topics/Tech Tips
10-28-2012 09:28 AM
feguy1
Exhaust System Topics
08-12-2012 04:41 PM
joe
04-20-2006 09:44 AM
