Torque for engine case studs
Old 09-14-2020 | 07:28 PM
Redrodyankneck's Avatar
Redrodyankneck
Default Torque for engine case studs
I noticed a bit of weeping engine oil collecting at the lowest point of the case. It appeared to be coming from the nuts on the case studs on the forward most stud.
I checked the torque spec in the manual and it was listed at 12-15 ft/lbs. Since these studs go through the cases with a nut on either side, what harm will it do to bump the torque up to try to stop the weeping?
Old 09-14-2020 | 08:13 PM
johnjzjz's Avatar
johnjzjz
17 is the max in auto alloy transmissions - oil studs - bolts in alloy threads - but the lower studs are press fitted careful what your attempting - you can remove the nut and seal it re torque and see what happens
Old 09-14-2020 | 08:17 PM
Racepres's Avatar
Racepres
Increased torque has Never worked out to the good for me... Mostly bad things have happened...and never has it done one bit of intended good...
Old 09-15-2020 | 06:40 AM
Redrodyankneck
Caution noted, Just for clarification, the "studs" pictured are actually rods with threads on each end. These appear to go through the case halves.
Old 09-15-2020 | 06:57 AM
t150vej's Avatar
t150vej
On the one that's leaking - Use aluminum flat washers, new nuts, and ditch the lock washers. Apply Loctite 222 (low strength / purple) on the threads and torque to spec. If you can't source the 222, substitute 242 but use it sparingly.
Old 09-15-2020 | 05:12 PM
johnjzjz's Avatar
johnjzjz
# 5 studs are tapered and fit very snug
# 3 stud if its leaking look for a cracked mounting foot - not always but sometimes we see that
Old 09-15-2020 | 05:26 PM
Redrodyankneck
Hi Johhny, The mounting foot looks good on both halves but I will check again! I did not see your most recent post before posting the following.
Bear with me as I explain what's bugging me.......
Here is a pic from the HD manual of torque specs , look at crankcase stud nut torque spec.12-15 ft/lbs. These are the nuts on the studs (rods) that pass through the cases and the torque value shows 12-15. Figure 3-34 ( 2.3.4. and 5.) shows them clearly. None of these use a tapped hole into the case alloy yet they are listed as having a torque value as if they were. (as Johhny said less than 17).
Now look at the Figure 3-34 again, crankcase stud BOLT, shown as 1. and has a torque spec listed as 22-26 ft/lbs. These bolts ARE threaded into a tapped hole the case alloy yet have a torque spec of 22-26, far exceeding the absolute max torque of 17 for alloy.
I am making the case that these torque specs are actually switched in the HD manual. Agree...Disagree?
Old 09-15-2020 | 07:04 PM
johnjzjz's Avatar
johnjzjz
different engines shovels had - some use a 3/8 X 16 bolt left side top of the block - some use 2 -- 5/16 X 18 bolts same place as the 3/8 and in the rear left side under the mounting bolts
not everything read is for a home owner to understand - its a work SHOP manual for shop workers - we see all the changes and different things you know nothing about
Old 09-16-2020 | 11:37 AM
Redrodyankneck
Understood. My shovel has 5/16 bolts also, not the 3/8 as shown in the manual.
I'll never be a shop guy as my exposure to shovelheads is limited to the one I own
I appreciate your candor.
Old 09-16-2020 | 07:13 PM
Racepres's Avatar
Racepres
Any machinist's handbook... even google ...will tell you the torque on a Thru bolt at 5/16 or 3/8 or whatever, if you Look... Not rocket science, and not exclusive to H-D....Simply identify the fastener and Go...
Do Not confuse your own self...
Quick Reply: Torque for engine case studs
