78 FLH Front Brake
Received 49,922 Likes
The following 2 users liked this post by old mago:
Racepres (07-20-2020),
Uncle Larry (07-20-2020)
How much drag is normal for a FLH front brake caliper?
Reason I ask is my '72 drags enough to heat up the rotor.... which doesn't seem right. I bled the system but can't seem to get the piston to stay in the caliper far enough to eliminate the drag. I had this happen MANY years ago on a new 78 FLH and recall it warped the rotor.
The following 2 users liked this post by Uncle Larry:
FLHS1990 (06-27-2024),
rockher_man (08-16-2020)
Almost... I know that You know Larry, if the little bleed hole in the MC is Plugged... the Caliper cannot release...
The following 4 users liked this post by Racepres:
My '72 FLH shows part number 45000-78 for the front caliper.
There are few used banana calipers around but they say in the description '73 and up.
Question: do the '73 up calipers fit the '72?
Are the front and rear '73 up calipers the same? Seems like more rear calipers for sale than fronts. I seem to recall they are identical but that's been many years ago.
Would prefer to retain original and don't want a new chrome plated made in china piece.
I rebuilt the original but the bleeder hole is buggered up and an adaptor isn't going to fix it.
