Thinking about a NEW rat rod build...
Old 10-04-2023 | 04:35 PM
Spumoni's Avatar
Spumoni
yeah - this is exactly what's happening to me. I can start it from cold, but warm is another beast. It seems to almost start after every other kick but isn't quite catching... but I'm afraid to give it too much gas. After several failed attempts, I will use the electric start, but even then it turns for a bit before it starts.
  #222
Old 10-13-2024 | 02:12 PM
Spumoni's Avatar
Spumoni
Well it's been about a year since my last post on this rat bike, and since then I've had a blast racking up about 6k miles on it! I'm only left with a couple mysteries I'm still trying to figure out. To recap:
-Newly rebuilt "shovelution" with an S&S complete bottom end, hydraulic kit, etc.
-Original cylinders and heads. (1200cc with standard compression).
-Single fire coil with Compufire ignition.
-Pipes have baffles, and the breadbox air filter is using oiled foam.
-64 main jet, .295 intermediate (super E carb)
-only use 91 octane non-ethanol
The main issue I'm having is the bike occasionally "diesels" when I shut it down. I'd say 1 in 3 shut downs, it will stumble. I know this could be timing, or a lean condition. Yesterday I realized my mixture screw was more than 3 full turns out, so I went up to a .031 intermediate, and it's like nothing changed, I am still more than 2.5 turns out for the right idle mixture.
To me, the 64 main jets seems small compared to what other guys are using, but anything larger and the bike starts to warble at high RPM's. (I'm still not sure if this could be the rev limiter, but it got much better with the smaller main jet).
I am also on the least agressive curve on the Compufire ignition. Anything more and the bike starts to ping a tad.
Eventually I will figure this out, but I'm wondering if I'm chasing my tail and should try another ignition, even though the Compufire kick start seems work great. Last year we tried the Ultimate dual fire, but it would only run on once cylinder not matter what we tried, so I went back to Compufire.
The following 5 users liked this post by Spumoni:
1981 suprglide (10-14-2024), AJSHOVEL (10-13-2024), Architect (10-14-2024), hellonewman (10-13-2024), Kenelz (10-14-2024)
  #223
Old 10-13-2024 | 04:53 PM
98hotrodfatboy's Avatar
98hotrodfatboy
64 on the main jet does seem small.. Normally a 74" motor would run a 0.028 or a 295 with the S&S E.. I'm pretty sure with the Compu-gire ignition that you have has a mechanical advance under there.. I ran one on my '77 and it worked great.. To me it sounds like mechanical advance is sticking.. it'll give you the run-on when trying to shut it off because he advance is staying full.. check the weights and springs to make sure they're not worn.. Make sure the shafts for the weights are not worn and the springs are nice and tight and it's working the way it should be..
  #224
Old 10-13-2024 | 06:33 PM
1981 suprglide's Avatar
1981 suprglide
wow wish I had that front brake caliper these bullseyes front caliper doesn't work very well nice rat rod impressive
  #225
Old 10-13-2024 | 10:51 PM
Spumoni's Avatar
Spumoni
I agree on those jets - not sure why the bike likes such a low main...
That compu fire ignition is all electronic - there is no mechanical advance. My previous ignition (Dyna) had the mechanical advance, which was a nightmare. John (from this forum) helped me fix that with a better spring mechanism and it was much better, but I ended up going back to a fully electronic.
Those banana calipers are probably the worst brakes I've ever experienced, but I really wanted them on this build because it's all part of that era. The drum brakes on my 1942 WL work twice as good!
Shovels & Vettes
Panhead
28
12-23-2019 07:37 PM
NL_Biker
Shovelhead
15
05-05-2018 01:51 AM
ohioguy
Shovelhead
07-07-2016 08:26 AM
25-06
Shovelhead
25
02-15-2013 02:17 PM
HB
05-24-2012 05:58 AM
Quick Reply: Thinking about a NEW rat rod build...
