Thinking about a NEW rat rod build...
#182
Just can't see John sugar coating it
The following 3 users liked this post by TwiZted Biker:
#183
TwiZted Biker (08-28-2023)
#185
I bought the American Prime at John's suggestion.
J&P is showing them in stock.
https://www.jpcycles.com/product/ame...ku_id=10215658
#186
#187
#189
I was confused because the Computer-Fire ignition that we just pulled out wasn't using a mechanical advance. The new DYNA ignition requires a mechanical advance. We found the old one, and it's exactly like you said.... SHITTY! So we will wait until you send me right mechanical advance.
Also, I was using a 3 ohm coil, but we just installed a new 5 ohm so hopefully that will help.
Architect (08-31-2023)
#190
I think the pretty standard jetting on the Super E is .295 and 70.
You have gotten way off from that. Larger in the middle and very small on the main.
Like i mentioned with my plug wire issue, sounds like your chasing your tail with the jetting.
Follow John and clear up any issues with ignition before making any more jetting changes.
The dieseling would usually be a super hot spot in the chamber or ignition still firing.
