Would someone please post a picture of the dash switch wiring for a 72 FLH. I have the wiring diagram but I'm not sure if I have the cables on the correct terminals. Also, where does the flasher for the turn indicators mount? Thanks.
your 5 oclock term is 12 volts in - ignition is at 11 oclock - do you have the correct 5 terminal switch or a 6
if you get the 5 oclock hooked with jumpers and they work turning the switch twice and it has power both times - the rest is lights - speedo - tail - headlights - stop light and the dash bulbs
the flasher is in the nacelle wire tie it to the grouping of wires - you could get a socket for it but they always fall out - from vibes
Thanks. I moved everything clockwise one post and it looks like everything works now. Even got the engine to fire on starter fluid after a long year trying to put this thing together.
ask away the guys all help out in the this section and will give you the correct info
Anyone have a clear copy of 72 FLH? Im rewiring the entire bike. ripped everything out starting fresh with all new soldered connections. Thanks Fellas!
