74-75 shovel head spark plug "science"
Hello to all...
I inherited my dad's 75 FXE Super glide and I'm going to try to get it started. (sadly he let it sit for 30 years)
So I'm gonna replace the plugs, was looking up the part numbers, and for reference sake the listed Champion number is RN12YC.
I removed the existing plugs from the engine and it has J12YC previously installed in it.
Normally, I would just chuck the old plugs, buy what's recommended, and be done with it.
After doing some homework by checking multiple brand spark plug listings it seems that 74 and earlier plugs have short threads and 75 and newer have long threads.
My dad was the only owner and with only 14k miles I don't see any reason to believe that the engine was ever worked on.
The cylinder heads clearly have short threads and so that is the plug I will be using...unless there is something else I should know.
I'm sorry about turning this into spark plug science but I did warn everyone in the title.
Thanks...
Thanks...
rockher_man (03-03-2020)
Received 1,107 Likes
The following 3 users liked this post by Baird:
The following 2 users liked this post by Rusty Axle:
rockher_man (02-26-2020),
thebartman1970 (02-25-2020)
I've seen one long reach plug in one head and the short in the other, from the factory like that. 74 through 79 were interesting times for shovels, most were as they should be but during transition years mix & match games did go on. 78 & 79's were all over the spectrum.
The following 3 users liked this post by TwiZted Biker:
Racepres (02-26-2020)
According to Service Bulletin 680, new cylinder heads were used as of October 28, 1974 and they required a longer spark plug.
But if the bike was produced before October 28 then originally it would have had short plugs and that seems consistent with the short-thread heads you have.
Maybe the bike is an early-75 model. Is there a sticker on the front R-H downtube of the frame? It may have the ‘Date manufactured’ on it indicating month and year.
Also, if it is an early-75 model then I imagine the VIN may be fairly low? For 1975 models the VINs for the Shovelhead family began at either 10000 or 10001. (FX/FXE/FL/FLH VINs were grouped together.)
Eric
Eric
The following 2 users liked this post by Speeding Big Twin:
rockher_man (03-03-2020),
Eric
Eric
My dad's FXE is missing the sticker with the date of production but the VIN sequence is 11824 which seems pretty low.
Thanks again.
