Rocker box rebuild
Rocker box rebuild
While disassembling/cleaning/inspecting/measuring the rocker box (rear cylinder) I noticed that the oil hole in the bushing is in a different location than the oil hole on the other rocker (in relation to the 'thumb' for the pushrod). Does this matter? Is the location of this oil hole important?
Edit;
I will look carefully today sometime in the shop... The Darn Evo Motor is different enough from the Shovel, to confuse my memory on top end oil!!!! And... Gettin older don't help that Memory...
Went and looked... but, I do not have a rocker without bushings right now!!!
Oil In to the Big end of the shaft, from the Box... shaft is hollow so oil to middle of shaft between bushings... Valve side, oil fron behind bushing to the "port" in the bushing... Pushrod side, oil from behind bushing to that port... and the bleed off/relief, oil is sent out the hole adjacent to the bushing hole, right out the Rocker itself... little hole at Pushrod side on top of rocker..
Splash oil is funneled from pushrod "rocker" to pushrod "tip" via that hole at top on rocker...
Prolly gotta hold the Rocker in yer hand and look at it while ya read my meandering, as My communication skills are suspect!!!! Just ask my Bitter Half!!!!
BTW... the ones I have here all of the "ports" are aligned like your second picture...and there is a relief hole right out the "top" near the Cup
I do not see the relief/bleed hole in your first picture... so I am confused right now...
Maybe later i can scare up some more examples!!!!
one more time
now I found a set with no port on either bushing. And a relief hole aimed at the valve side rocker, toward the valve tip!!
and there is no funnel at pushrod tip, it is hollow and oil comes out of it
note there is Not an HD part # on these last ones!!
one more time
Bumpandrun (01-27-2020)
marine_hm@hotmail.com
09-15-2012 12:41 PM
