76 FXE Clutch Adjusting Srew Nut Question
Thanks for everyone's help on my other posts. I'm actually progressing right along.
1. What is pictured/subject nut torqued too?? Do you use locktite on this nut?? (White arrow)
2. When does the adjusting screw come into play? Didn't see (or couldn't find) anything in the manual on it. (Red arrow)
Thanks in advane!!
Thanks in advane!!
the arm correct location is 1/2 inch off the starter for the correct travel and fulcrum
we bring it in the screw till its just influencing the throw out bearing then back off till its just loose - tighten nut with out turning the screw
then you adjust the cable that is total loose so it has no influence in the first start adjustment above
rlj50
10-23-2015 05:43 PM
