1969 FLH Shovelhead Build is a Radical Swingarm Chopper
By Bruce Montcombroux
Vintage Big Twin project was a learning curve.
I cant sell anything that looks like that - it is not what the kids want -- whats wrong
its a 79 FX or later swingarm frame my guess its how its titled and the engine is a re pop flatside - rear passenger peg mount and swing arm give away - they want hard tails no one has asked for a swingarm bobber
ok it has turned down fork tubes -- BUT they are also FX with the Chinese's wide stance 35MM tube front trees -- < you get laughed using it
the seat would not be a mans choice as the kids are too big to take that kind of hit on bumps
I always disliked that communist oil tank and it appears to be kick only why use an electric start china ugly oil tank
Mr leaky sold him those stupid rocker box nut things - first thing I remove and throw away first time the bike comes to the shop - not going to hear it was not leaking when I brought it in for a tire replacement
I don't see a pet **** on this side maybe someone else does - its a tunnel tank and maybe 1 1/2 gallons but you need two pet ***** to get it all - or when it stops you need to lay it on its side before it gets the other gas on the other side
and disc brake is also a no no with the guys we see - hyd rear drum sure but not disc
just picking some things out I see not a homeowner build at best and he had no money to spend
I just did the bottom of the fork looks sporty to me but I have never even look at a newer bike since the early 90s
and spinning that leg they cut it straight up from the bottom a 41 top would be real thin at the seal
and the top fork to tree looks small to me but its a photo - so ok maybe your right but 39mm is my guess not 41
And yet, it could be 39mm... which is much too new to me.. I haven't had a ton of experience with modifying 39's... I guess I don't really recall if they have Caps on one or both sides... 35mm being both sides..Showa's anyway..
Have to agree with john's original statement.. Crap seat, and 35mm front... Judging by the front down tubes the legs aren't much bigger. The only thing period correct would be the frame and the "tree's (possibly)" As for the tank, very possible it returns to the left side at the very rear of the tank. It appears to be above the back bone..
Its a 69 Frame. 66-69 Shovels were all Swing arm. The swingarm itself is a 70s model square style swing arm. Its got OEM cases and title.
they are 41mm fork tubes. Late model lower tree. Which is easy to pick out. 35mm are way skinnier. The fork legs are shaved late model lowers that were tapered.
The seat is actually really comfortable with the shocks.
Probably a repop oil tank yeah, but looks good. The chain would eat the back of the tank if it didnt have the cut out.
The Rocker box nuts have never leaked.
Theres only one petcock beause there are 2 cross overs. Holds 2 gallons. i dont have to tip it at all.
Disc brakes work great.
Like i mentioned, Its my bike, I used what I want. Garage Built. If you dont like it, Cool.
