rocker arm shaft
Old 10-23-2018, 09:16 AM
1984 flhs's Avatar
1984 flhs
1984 flhs is offline
3rd Gear
Default rocker arm shaft
i have a '84 flhs and i'm leaking oil from the the rocker arm shaft on the front cylinder, so my good buddy says pull it out and replace the o-ring. i do and now can't get the shaft back in. is there a trick to this or is this going to a mechanic?
Old 10-23-2018, 09:26 AM
Kingglide549's Avatar
Kingglide549
Kingglide549 is offline
Should of could of- if you had followed out with something going in @TDC you woud be OK,
Now the rocker is not lined up with the hole and you are just bumping the side of it.
If you bring it up on TDC and fuss with it from the other side you might do it.
other then that pull the rocker box.
No big deal-20 min work
1984 flhs (10-23-2018)
Old 10-23-2018, 01:44 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,401 Likes on 1,721 Posts
I have not been able to pull a Rocker in the Bike on a Shovel.... Head and all No Problem.
Old 10-23-2018, 02:10 PM
1984 flhs's Avatar
1984 flhs
3rd Gear
ok will try that thanks
Old 10-23-2018, 02:37 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,853 Likes on 3,019 Posts
remove the pushrod completely and try that
the rubber o ring may fix it / and they make an over size o ring for that as well -- but the white nylon replacement square ring is the go to for a fix in a shop
Old 10-23-2018, 04:04 PM
1984 flhs's Avatar
1984 flhs
3rd Gear
been screwing with this all day, i have a feeling it's going to the mechanic tomorrow, but thanks
Old 10-23-2018, 04:11 PM
Kingglide549
Just remove the rocker box for gods sake
Old 10-23-2018, 05:36 PM
1984 flhs's Avatar
1984 flhs
3rd Gear
i'm a crapy mechanic, i need supervision
Old 10-23-2018, 05:43 PM
Kingglide549
Its too simple
You better bone up if you are going to own a Shovel
.Remove gas tank
Rolll cylinder to TDC.
Loosen push rods, remove rocker boxes
Pichilingo (08-26-2019)
Old 10-23-2018, 05:51 PM
Joe12RK's Avatar
Joe12RK
Joe12RK is offline
Received 1,598 Likes on 976 Posts
does an 84 use studs and nuts or bolts to hold rocker boxes on?
Quick Reply: rocker arm shaft
