1975 funky frame
Old 09-28-2018 | 11:51 AM
Tee&Vee's Avatar
Tee&Vee
Default 1975 funky frame
Hello,
This frame has good paper and the down tube sticker and neck match.
It looks like somebody flipped the swingarm on the bike at one time. Also there are two blocks that seen to be missing as well. Are they the passenger peg mounts by chance??
Flipping the swingarm will lower the bike dramatically from what I gather, I mean the geometry would be such that it would be pointing down, right?? I'm guessing unless fixed then it would need shorter shocks.
Please give me your thoughts! TIA
Old 09-28-2018 | 12:24 PM
biginchhustler's Avatar
biginchhustler
you need to ask someone like johnjzjz or raceprez - they have more knowledge of stuff like this --
Old 09-28-2018 | 03:29 PM
Tee&Vee's Avatar
Tee&Vee
You're not wrong! Thanks.
I'm hopeful they'll add their knowledge to this. I also know TwiztedBiker has chopped as many shovels as anybody else.
Fingers crossed!
Old 09-28-2018 | 04:38 PM
Joe12RK's Avatar
Joe12RK
I don't see a swing arm, but the two-hole blocks on the back of the frame would be for passenger pegs.
Old 09-28-2018 | 06:20 PM
johnjzjz's Avatar
johnjzjz
I don't get Y you think the swing are mounts have been dropped - measure from center of the thread hole on both side to the bottom of the top frame rail tubes extensions and I will compare it for you
the threads look a little damaged but I don't have it in the shop - do you have the swing arm cross bolt -- they come in self tapping oversize threads in 2 sizes larger - we have welded the hole and drilled and tap it - but you need a frame jig to do it correctly
the thread is on the correct side - that allows the swing arm removal with out pulling the inner primary
Old 09-28-2018 | 08:45 PM
TwiZted Biker's Avatar
TwiZted Biker
Swing arm mounts are fine on the black frame, they didn't add the blocks are you talking about till later years. As John says the pivot bolt threads look a little roached but I've helicoiled a few over the years with no issues, having a bare frame for that repair helps loads.
Old 09-28-2018 | 09:45 PM
Tee&Vee's Avatar
Tee&Vee
Thanks for the replies fellas! I'll get a better pic this weekend.
Thanks again!
Old 09-29-2018 | 08:04 AM
Racepres's Avatar
Racepres
Frame looks fine to me
but I’m on phone
the passenger peg blocks were added sometime after 1974or 5
swangarm modifications were abundant
i don’t see it here
BTW
a square swingarm flipped only moves the shock mounts. While loosing the guard mount, and the brake stay.. Flipping a round swingarm?? Never seen it I’ll have to look... later
Old 09-29-2018 | 08:00 PM
Speeding Big Twin's Avatar
Speeding Big Twin
Old 09-29-2018 | 08:19 PM
Tee&Vee's Avatar
Tee&Vee
Thanks for the photos, Eric. I thought you would have something good for reference. Here as a few I just took. I think it's obvious the swingarm was flipped, not moco welds to my eyes.
Quick Reply: 1975 funky frame
