2/4 plug compression release
08-02-2018, 09:43 PM
I have an 81 shovel that has two plugs on one side and compression releases on the other. I don't care for the compression releases. Can I remove the releases and install two more plugs? I have a morris magneto that only has two wires. Do they make a four wire set up?
08-03-2018, 06:34 AM
they did make a 4 wire set up for a mag not sure if they still do
if the threads are 14 mm then you can swap it out sometimes you find a thread reducer
08-12-2018, 10:39 PM
Morris does make a 4 wire set. $179 I found.
08-13-2018, 05:52 AM
Why 2 plugs on one side? I thought the purpose of Dual plugs was to help the burn on both sides of the piston dome.. One plug on each side.....
08-13-2018, 07:45 AM
Quote:
Originally Posted by
98hotrodfatboy
I took it to be left and right side not just the left
08-13-2018, 08:34 AM
on plug in each cylinder on the left, one comp release in each cylinder on the right = two on each side...
Ndoggct
09-21-2016 07:02 PM
sober1
09-29-2015 09:52 PM
Ragnar Danneskjöld
05-01-2013 10:30 AM
oldairboater
06-24-2011 09:43 PM
zenwarrior
08-30-2006 03:56 PM
