72 shovel runs sputters, backfires, dies
hey guys,
pretty much stock shovel with sifton cams/lifters and bendix Zenith. Bike runs fine for about a mile after starting and then starts sputtering and backfiring and eventually dies. Then I sit for a minute, start it up and it runs for 1/4 mile or so and does the same.
here’s my thought: I think it’s a fuel delivery issue. I’m going to drop the tanks, rinse them out, take out the petcock and clean it and the screen. I already took out the inline fuel filter. Someone said it’s one or the other: screen or filter but not both.
i began draining the tanks and it took 15 minutes to drain about 1/2 gallon of fuel, so,that’s a clue.
I’m asking just in case there’s something I’m overlooking or if it continues after I clean the tanks because I’ll have some time this weekend to work on it.
TIA, y’all! Happy riding this 4th and God Bless America!
Bill wallace (06-29-2018)
The following 2 users liked this post by coax9952:
Bill wallace (06-29-2018),
TwiZted Biker (07-01-2018)
Coax, Carl and pjb, brand new build. Rebuilt carb and works fine. New fuel lines and fuel hasn’t been in it for more than a few weeks. Basically everything is new or rebuilt on the bike. Ultima electronic ignition. Thanks for the replies, guys. All good ideas. I could’ve mentioned that in my post, but I had to end it somewhere.
The following 2 users liked this post by RDHIGH:
Kingglide549 (06-29-2018)
LOL Badass?
Pull the plugs stick the wires back on them and crank it over. or kick it over, whichever - with plugs firmly against engine
You will see a nice blue spark.
You don't?
in your case replace coil and condenser.
The coil will go bad as all electronics do with heat, age etc.
Most important, get a coil for a points system!
Being you are stalling out after it warms up and runs after cools dwn---probably is the coil.
keep in -mind do check your fuel delivery B4 you do this.
the next time it stalls out unhook fuel line from carb-does fuel run out?
Yes?
Replace coil
Bad ***-
a long time a go doing inserts in HOT LZ, scared as hell.....to the point of being numb
Is that a badass?
Or like most soldiers-doing what we should,
You don't?
Yes?
Replace coil
Bad ***-
Is that a badass?
Received 49,886 Likes
