Carb or ?
Carb or ?
Ok so I have this issue that's got me stumped at the moment, 84 fxsb, super e carb, 74/295 jets, points ign. hyd lifters, here's the problem, cold start, starts right up and idles good without the enricher open but smells a little rich to me, take it down the road and get it warmed up and let it idle at a stop or in the shop and it will randomly spit out the carb, sometimes it sneezes enough to kill the engine, only at idle, runs good down the road and pulls hard, I've static timed it few times to make sure it was on and also moved it around while riding the bike and it doesn't effect the problem at idle, also on my second set of intake rubber bands just to make sure, I have the red silicone bands on it now with no change in the problem, I haven't pressure tested the intake for leaks yet but have checked for vacuum leaks with carb cleaner, any ideas ?
while a agree the 74 main Might be to big he has been riding it and now he has a low speed lean issue
todays gas causes a film that film builds up inside the jets and even the carb body
if you remove it disassemble it and sonic clean the carb and the jetting - if at that point you find its choking rich at hi speed drop the main back to a 72
First, I appreciate all the replies so far, keep em coming, here's a little background on my bike, what I know and don't know as of today, I picked up the bike about a yr and a half ago knowing it had been setting for a few yrs, I did fire it up before buying it just to see it run btw, knew it had some leaks and clutch issues up front, owner was a straight up guy just didn't have a clue about shovels, no fault of his, when I got it home and in my shop I pulled the tanks, cleaned, and resealed, changed the oil, filter, adjusted the valves, plugs, pulled the super e and cleaned and rebuilt it, the carb was unsupported with a big *** bug catcher on it and the intake bands and clamps were mangled , fixed now, now that I could run it a while is when the spitting out the carb issue showed up, checked the usual suspects, intake leaks, pulled the carb again and checked jets etc, run my micro drills through them to make sure, originally had the factory hd electronic ign on it with no voes to be found, po had the timing pushed way up and pinging bad pulling me under a load, pushed the timing back and naturally dropped the power and pinging but didn't effect the spit at idle, fwiw I grounded the voes wire and it seemed to not effect the timing at all so I assumed an issue with the unit, I converted to points with correct coil etc, no change, checking the plugs after a hard run they don't too bad to me but the do look rich after idling for extended period but now fouled out I believe, now what I don't know is what cam, pistons etc are in the eng, the po said he had it rebuilt and they put a bigger cam in it, that worries me a little and I haven't looked in there yet to check it out, I will add that when hot even with the timing set back just enough to not ping on a hard pull it will kick back on the starter like a **** but I usually kick it over without it kicking back at me, also I have 110 psi on both cylinders, hot and dry, oil made no change on compression numbers, 110psi doesn't seem high to me but kicking it seems like it's pretty stout, maybe I'm just getting old though.
Carb adjust
