Flywheel timing marks
Old 06-24-2018 | 07:58 AM
Bill wallace's Avatar
Bill wallace
Default Flywheel timing marks
Hey guys,I installed an Ultima electronic ignition in the 72 shovel head. Instructions say to bring the front cylinder up on top dead center and align the timing mark in the hole. There are two timing marks on the fly wheel, a line and a dot. My factory manual says the line is 35° advance. The instructions say to rotate the module in the cam cover counter clockwise and then rotate the engine until the LED light comes on and the timing mark is visible in the hole. then, rotate the module clockwise until the light just turns off, and the motor should be static timed. I can’t do this with the line: the light won’t turn off. I tried rotating the engine 180 degrees just in case it was on exhaust stroke. . No luck. The bike backfires and sputters. So I’m using the dot, but it’s not working.
Old 06-24-2018 | 09:11 AM
JAMES2's Avatar
JAMES2
Do you own a manual for that bike? there could be more than two marks. Pull the plugs and try again...
Bill wallace (06-24-2018)
Old 06-24-2018 | 12:18 PM
Bill wallace
Thanks for posting that. Yes, I have a factory manual. I didn’t see that exact picture. I’ll flip to 3-21 when I go out. So I’m good. Must be a carb problem. I also buggered up the crankcase breather and plugged it. That might cause backfires, fouled plugs and tapped block leaks. Going out to fix that right now.
Old 06-24-2018 | 01:27 PM
TwiZted Biker's Avatar
TwiZted Biker
Make sure you are on the compression stroke when you do it, don't use the dot.
Fblo1690
EVO
24
05-20-2018 01:05 PM
89FLHTC
EVO
19
12-02-2015 10:07 PM
walteria13
Ironhead
22
10-05-2011 08:30 PM
priobe
03-08-2010 03:48 PM
sugarplum247
Ironhead
18
04-20-2009 06:00 PM
Quick Reply: Flywheel timing marks
