Shovelhead charging question!
Old 06-12-2018, 05:09 PM
83hdfxrs's Avatar
83hdfxrs
83hdfxrs is offline
Default Shovelhead charging question!
I have an 83 harley fxr. I had a little problem I think. My batter at idle is reading 12.7 volts even when i rev it. I thought the battery volts will go up when you rev the bike. I tested the stator it self and was getting 22 volts, did an ohm test no breaks in the wires or any shorts. Is my battery charging and I'm over looking it?
Old 06-12-2018, 05:14 PM
Baird's Avatar
Baird
Baird is offline
Received 1,105 Likes on 456 Posts
seems like regulator trouble. did the ac volts from the stator climb when you increased RPM?
Old 06-12-2018, 05:24 PM
Racepres's Avatar
Racepres
Racepres is offline
Received 2,412 Likes on 1,728 Posts
Not that difficult really...
record/note
1] Battery Voltage, at rest [Not fresh off the Charger]
2] Battery Voltage, Key On...
3] Battery Voltage, Starter Engaged
4]Battery Voltage, at [High] Idle.
22VAC from the Stator seems Low... with a Half Wave rectifier that is Not even 12v!!!
Old 06-13-2018, 02:17 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,187 Likes on 5,846 Posts
19-26 volts @ 1000 rpm
Old 06-13-2018, 03:10 PM
Racepres's Avatar
Racepres
Racepres is offline
I stand Corrected [Again] I guess they must use a better rectifier!!
Makes it easy tho... If the Battery goes Down with use... ya need a regulator I Think...
Old 06-15-2018, 04:38 AM
tpb857's Avatar
tpb857
tpb857 is offline
Veteran: Marine Corp
My 73 FL just had the same problem. It was not charging at all. It was the stator. As long as I was in there, I just got a kit for an Evo system, which consisted of the stator, rotor and regulator. Works fine now.
Old 06-15-2018, 07:34 AM
83hdfxrs's Avatar
83hdfxrs
83hdfxrs is offline
I bought a brand new voltage regulator $140. I made sure it was grounding, clean the bracket and everything. Im still getting 12.7 volts. Even when reving and idle. I tested the stator every way till sunday and it passed.
Old 06-15-2018, 08:10 AM
Racepres's Avatar
Racepres
Racepres is offline
If it don't ever get lower... Who Cares??
I feel as long as the Charging system can "keep up" all is good...
Admittedly Odd Scenario... but, again, I would Not sweat it till it really is a Problem!!!
I'm curious what the battery sits at when bike is Off!!!!
Old 06-15-2018, 09:12 AM
Tom84FXST's Avatar
Tom84FXST
Have you tested the battery? Some faulty batteries will not take a charge...therefore the regulator will not put out.
Have you tested your meter on another battery...like you car?
Old 06-15-2018, 01:05 PM
Racepres's Avatar
Racepres
Racepres is offline
Good idea to check the meter... especially if it is one of those Harbor freight freebies!!!!
and
record/note
Quick Reply: Shovelhead charging question!
