Whinnig noise
the bottle gear bushing has not been used in 3rd gear since 1958 maybe, we see them from time to time but I usually convert the kick only trans to the later 3rd gear and his trans is not a kick only or should not be at an 82
when we take them apart hearing a noise in third its usually the washer to gear has lost its lubrication - you will need to go looking after you get back from your trip just go easy in third
what oil do you use in the gear box ?????
I fixed a '74 from that not that long ago too...well... few years!! Wonder just what I did??
Better watch this Thread huh????
it might be a few things but the gear box needs to be disassembled and looked at carefully not to miss something
funny that its second and third -- second is driving off the countershaft into the main shaft - But third is driving off the main shaft into the counter shaft -
my off the top wild card guess the countershaft thrust washer seized and caused no oil to enter into the countershaft rollers on that end - left side of gear box
