Gas tank leak, Repair of the leak repair
My '83 FXDG gas tank has developed a leak, and upon inspection it was discovered that a previous owner sometime in the past has attempted a repair.
So, I am going to attempt to repair the repair or, more correctly, remove the previous repair attempt and to make a proper leak repair, short of tank replacement.
I have attached two photos. One is of a portion of the previous repair material that I removed.The repair material is only on the bottom portion of the tank, not completely covering the whole interior of the tank. The material appears to be some sort of epoxy that eventually delaminated from the metal.
The second photo is of the interior in the general area where the material was removed.
I have several questions:
1. What is the best way to remove the remaining repair material, if it can be removed at all?
2. What is the best method of prepping (Cleaning) the tank for the new repair material so that it bonds completely?
3. What is the best method and brand of repair material to for making a permanent repair?
Received 5,440 Likes
AJSHOVEL (02-14-2018)
But, I made a Temporary repair about 3 years ago with Seals-All
No Immitations, the real stuff... Think I'll leave it awhile yet, as I ain't ready for Paint!!!
Agreed, I had to go to the next County to find a guy. He went from being a Radiator Repair Shop to a vintage car and bike tank repair guy. Good for him, all of his competition retired and he made a niche for himself. If you are the only guy in two counties, there will be enough vintage vehicles to keep you busy. And he is busy.
Solder isn't going to work so don't waste your time. Pop in a pic of the outside area that needs repair, I've welded more shovel tanks than I care to remember, my sig bike's have been repaired twice.
What I wound up doing is brazing the area.
I've already reinstalled the left tank that had the problem and I didn't take any photos. My bad.
The leak was in the area near the petcock opening. It appeared to be a small crack about a quarter inch long, like the tank may have been dropped at one time and they tried to repair it with a JB Weld type of material that finally delaminated.
Brazing seems to have done the trick so far. The trick is to really get the area clean so there is good adhesion with the two metals. Time will tell.
You're correct, soldering doesn't work.
BINGO..... Before brazing, use a very fine drill bit (approx. #55 .052) , drill a small hole at each end of the crack (this will prevent the crack from walking when heat is applied).
