CV Carb
The addition of the Flange onthe CV is kind of a Fragile connection, and the Carb needs to be supported... Not the Flange [which is Perfect for Most Carbs]
I always tie the Air cleaner to the two tapped spots on the bottom side of Shovel Rocker Boxes.. [later ones anyway] with a Fairly stout strap... at each rocker too.. Again, That Pressed on Flange on the CV is Fragile, especially after you Shake it Awhile...
Not that I know of... Just sayin the problem is exacerbated on rubbermounts, but, I will Not go with a Flange support on a CV conversion on a Shovel... Even a Solid Mount Engine..
Excuse me for Daring to Counter what you have Proposed...
^^ This is the Better way... no Matter what Air Box you choose.
[QUOTE=Racepres;17064108]Not that I know of... Just sayin the problem is exacerbated on rubbermounts, but, I will Not go with a Flange support on a CV conversion on a Shovel... Even a Solid Mount Engine..
sorry I was busting you - the my key board has no sarcasm buttons
[QUOTE=johnjzjz;17066609]
Understood... I'll adjust my sensitivity Dial!!!!
That is a pretty nifty job there... if I liked that Air Box I would copy that!!!
I always end up with good ole bent flat stock!!!!
