Shovelhead Cams
Old 09-29-2005 | 03:10 PM
JugsReturn's Avatar
JugsReturn
Default Shovelhead Cams
I have a 80 XL (sporty) with a 1000 cc shovelhead motor. The tranny blew out this past summer so I think its time to rebuild the bike from the ground up. I would like to put bigger cams in the ol' shovelhead. Any recommendations? Thanks for your time.
JUGhead
Old 09-29-2005 | 06:20 PM
HDWRENCH's Avatar
HDWRENCH
Default RE: Shovelhead Cams
As far as cams go there are plenty I favor the andrews cams myself as they offer good performance and easy gentla ramps. Sifton has some good ones as well as leinweber but they tend to be very noisy. I have had great done plnety with andrews and have had great results
Old 12-13-2005 | 09:19 PM
lennyeagle's Avatar
lennyeagle
sifton had some great cams, for cast iron sportsters but at this time sifton is closed and no longer manifacturing in san carlos calif. the machines were sold to one company and another the name only. product is being distributed under the name but nothing made or designed by sifton cams. i know this is a fact i was the product mng for the company for many years. tom sifton has passed away a great racer and performance product manifacturer.
rockher_man (08-12-2020)
Old 12-13-2005 | 10:09 PM
MegaHDman's Avatar
MegaHDman
ORIGINAL: JugsReturn
JUGhead
Where do you want the powerband? Do you plan on setting up your compression and heads properly to match the cams or are you just doin a basic rebuild on stock ironhead heads.
BTW, your Sporty engine is an 1000cc "ironhead", not a shovelhead bigtwin, unless there is something your not telling us.
Old 08-11-2020 | 03:30 AM
Justabill's Avatar
Justabill
1st Gear
Default Shovel in a sporty frame?
JUGhead
Whwn you say shovel are you referring to your sporty cast iron head motor? Shovehead motors have aluminum heads 1980 sporty motors have cast iron heads and 4 cams instead of just one like a shovel does I just want to be clear about what you have.though they might resemble a big twin shovel top end it's not a shovelhead they are called an ironhead .that should help you when your referring to your bike.there are only a few cams out there for ironheads Andrews p cams are a waste of money the very least to consider are the PB+ cams the Y cams make better power and work really well with lower gearing to spin the motor at a higher RPM
where the Y cams want to make that power red shift from zippers makes higher HP cams but again at a higher RPM the question really should be how am I going to be riding my sporty?
Old 08-11-2020 | 11:20 AM
Racepres's Avatar
Racepres
Well said... for late Ironheads replacing the Q cams with good ole P's is the Bomb!! Very hard to beat in fact!!
My Bone Stock '77 [with P Cams] has been 12.98 @ 100.96... standing start 1/4
Old 08-11-2020 | 04:04 PM
johnjzjz's Avatar
johnjzjz
WOW answering a post from 2005 you guys most be really bored
The following 2 users liked this post by johnjzjz:
Nick Sorgio (08-11-2020), rockher_man (08-14-2020)
Old 08-11-2020 | 06:32 PM
Racepres's Avatar
Racepres
Yup...
Old 08-11-2020 | 06:56 PM
old mago's Avatar
old mago
yeah ..i wonder how he got on???
Old 08-11-2020 | 08:55 PM
Racepres's Avatar
Racepres
Prolly got the Hint, and moved to the Ironhead Sportster thread!!! I Hope
old mago (08-12-2020)
Quick Reply: Shovelhead Cams
