True duals on a flhtcuse2?
anybody expirience any problems with true duals?? i read somewhere that i may have to make an adjustment with the left passenger floor board to make the pipe fit. is that correct??? and any recommendations on pipes and mufflers??? i'm thinking V&H ovals or samson rolled thunder???
I have the V&H dresser dual and oval mufflers on my '06 SE Ultra and really like them. Great sound. Loud enough but not too loud. I tried about 6 different sets of mufflers before deciding on the Ovals. The true duals and a good tune with either a SERT or PowerCommander will also make your bike run cooler. I'm using the PC along with the Ness Big Sucker air kit.
Have not heard of passenger floorboard problems. Early Reinhart pipes had an issue with rear break pedal clearance on the front heat shield, I think that has been corrected. V & H comes withspacer washers for the driver floorboard clearance issues. Other than that, the only problen is gittin the old clunkers off if you plan to save then, otherwise just use a recipricating saw on the crossover. Good luck!
