LED Turn Signals 2011/12 SG
Hi guys and gals,
Dont post on here much but look a couple of times a day and learn a lot!
This is my second SG and my first CVO which I always wanted, my question is, I love the LED rear turn signals on the bike but I do think HD were a bit short sighted by not fitting LED front turn lights.
Has anyone upgraded the fronts, just LED bulbs? or the complete light unit, with rear LED and the Canbus, do I need an electronic gizmo?
Ride safe
Ride safe
Hi guys and gals,
Ride safe
Ride safe
Yep, lots of folks have.
Check out "Custom Dymanics". Bright LED's day or night.
Also you WILL need a load equalizer too. They have them too! You will need the 8-pin one if I am correct since you have alarm and is made for the CVO's. If you don't get the load equalizer, your bike will think you have a burnt out bulb and your blinkers will fast blink.
This is truly a plug and play set up. 2 LED's lights, and loader that goes underneath your seat and plugs right in!
Good Luck and Ride Safe,
YELLOWBIRD
So yes, you WILL need them. One of the easiest mod's to change out. Not to mention, they match the rear LED's, can be seen clearly during the day and make a very BIG difference while riding at night! Well worth it, I must admit!
Ride Safe,
YELLOWBIRD
YELLOWBIRD
YELLOWBIRD
I just put the CD led lights on my 09 cvo road glide and although I was told I needed the load equalizer, which I bought, I put the lights in first and tried them and they work perfectly without the equalizer, going to return it today. you might try it first, as my alarm, signals, 4 way flashers and even brake lights work just fine
Well guess what? I did. It seems that some scoots did or didn't need a load equalizer. Doesn't make sense to me.
Ride Safe,
YELLOWBIRD
