2006 SE 103 cam choice?
Old 12-07-2011 | 03:15 PM
jus2anoyu's Avatar
jus2anoyu
Default 2006 SE 103 cam choice?
I am gonna do some 30K maintenance this winter to include cam chains and shoes. Might consider changing cams. 2 questions, should chains be changed?, and can anyone recommend a cam option for a basically stock 103 with a good open air cleaner and a D&D fatcat?
Thanks,,,,
Old 12-08-2011 | 09:06 AM
zubaugh's Avatar
zubaugh
Smile 2006 SE 103 cam choice
I put S&S 590's in my 2006 SEUC
Duration not lift. Gear Driven and an easy and quick change. Not sure if there's a stock map as I had my SERT dynoed.
Old 12-09-2011 | 05:24 PM
tom149's Avatar
tom149
6th Gear
I put the Andrews 54N in my FLHTCUSE along with the hydraulic cam conversion kit and I really like it. You may want to put a thinner head gasket in to bump the compression a bit. The 54's like about 10.1 or 10.2:1 compression.
Tom
bedelman10
Engine Mechanical Topics
98
07-21-2016 08:00 PM
Wmitz
05-17-2014 09:47 PM
PHA-Q
Exhaust System Topics
04-29-2011 11:28 PM
maineultraclassic
12-16-2006 08:52 PM
tnt
12-01-2006 07:54 PM
Quick Reply: 2006 SE 103 cam choice?
