stage 1
No, don't waste your money. All it does is move the rev limiter to 6250 RPM. Dealers can not do anything to the bike that would change the factory emissions. The HD stage 1 air filter is junk. Go with an aftermarket like a K&N and a fuel management system like a TTS or fuel pac. You don't need to make any fuel changes if you add the air cleaner, engine maintains the lean factory F/A ratio even with aftermarket exhaust and AC changes. Again the only way to change this lean condition is with a programmable aftermarket fuel management system. Good luck.
lanceropolis
02-27-2009 06:08 PM
