Dim Instrument Lamps
Old 02-02-2010, 09:27 PM
SKYCLIMBER's Avatar
SKYCLIMBER
SKYCLIMBER is offline
Default Dim Instrument Lamps
All of the instrument lamps are dim and cannot be seen in bright daylight. My 08 I could see them in day light. Can't see 6th gear, check engine, low fuel. Anyone else have trouble seeing these lamps in bright daylight.
Old 02-04-2010, 06:16 PM
2harleys's Avatar
2harleys
2harleys is offline
Smile
Same bike, same problem. I think my problem is mostly age related. Don't know if you are experiencing that problem or not?? Those darn lights are just to small.
Old 02-14-2010, 09:04 AM
Puzzled's Avatar
Puzzled
Puzzled is offline
I changed the fairing bulbs to LED's on my 01 SERG. The Speedo and Tach have to be sent out so I didn't touch them.
Old 02-21-2010, 01:31 PM
digga25's Avatar
digga25
digga25 is offline
All the lights in my guages are covered with a red plastic cover which dims the **** out of them.Is this supposed to be like this?
Old 02-21-2010, 09:59 PM
SKYCLIMBER's Avatar
SKYCLIMBER
Not sure if there is a red filter on the green neutral light or the yellow low fuel light. I could see these on my 08 ultra in the daylight.
Old 02-22-2010, 10:32 PM
HDRick's Avatar
HDRick
HDRick is offline
The bulbs inside the four small gauges have a red "rubber " cover on them to make them red. It looks like a condom or balloon. The bulbs can be replaced with LEDs to increase their brightness. Like Puzzled said, the Speedometer and Tachometer are sealed.
Old 02-22-2010, 11:10 PM
SKYCLIMBER's Avatar
SKYCLIMBER
Thanks for the reply.
Old 02-23-2010, 12:01 AM
LEGENDCHROME's Avatar
LEGENDCHROME
LEGENDCHROME is offline
The gauges are sealed, however they can be changed. The spun gauges do make it harder to see the idiot lights. The engine light and 6th gear, as well as the security light are actually colored Leds, the only filter under the gauge face is a diffused clear overlay. I changed my security light to green when I changed my gauges other LED's. Changing to a higher power Led would greatly increase visibility.
Old 02-23-2010, 09:40 AM
SKYCLIMBER's Avatar
SKYCLIMBER
Thanks. I was just trying to see if this was a proplem on my bike or are all 2010's this way. Do you know the size or shape needed to fit and what is the output rating on the old lights so I can replace them with something brighter. Maybe the replacement LED lights for the 2008 will fit in the 2010. Think I will call the dealer today.
Old 02-23-2010, 10:43 AM
LEGENDCHROME
the replacement led's for the mini gauges can be purchased here
http://www.superbrightleds.com they are just replacement units for the stock bulbs, any of them will be a lot brighter than the stockers. The LED's for the speedo and tach are a bit more complicated than that, they have to be bought and soldered into the stock locations.
Quick Reply: Dim Instrument Lamps
