Any place to see features of SE Ultra?
The Harley web site lists most everything. Other than that, the CVOHarley forum is about the best place for CVO info.
By the way, for the first time ever, the MoCo is about to release a mid year Ultra Classic that will attract a lot of attention (black and sliver or gray). I've saw pics of it but they're not available to the public just yet. You may want to wait a few weeks and take a look at that one. It will be unveiled at the mid year dealer's show.
As of right now, the 2010 SEUC (Screamin Eagle Ultra Classic) in the burnt orange and citrus is about the prettiest Ultra Classic out there. No, I don't own one but if I had an Ultra Classic, that'd be the one!
https://www.hdforums.com/forum/gener...-se-ultra.html
Length 98.2 in. 2494.28 mm Seat Height
Laden2 27.4 in. 695.96 mm Unladen2 29.8 in. 756.92 mm
Ground Clearance 5.1 in. 129.54 mm Rake Steering Head 26 26 Trail 6.69 in. 169.926 mm Wheelbase 63.5 in. 1612.9 mm Fuel Capacity 6 gal. 22.71 L Oil Capacity 4 qt. 3.784 L Weight
Dry Weight 887 lbs. 402.3432 kg Running Order 924 lbs. 419.1264 kg
Luggage Capacity
Volume N/A cu. ft. N/A cu. m Weight N/A lbs. N/A kg
POWERTRAIN
Engine3 Air-cooled, Twin Cam 110™ Air-cooled, Twin Cam 110™ Displacement 110 cu. in. 1803 cc Bore 4 in. 101.6 mm Stroke 4.38 111.252 Engine Torque J1349 J1349 Engine Torque4 115 ft. lbs. 155.917 Nm Engine Torque4 3750 rpm 3750 rpm Fuel System5 Electronic Sequential Port Fuel Injection (ESPFI) Electronic Sequential Port Fuel Injection (ESPFI) Compression Ratio 9.15:1 9.15:1 Primary Drive Chain, 34/46 ratio Chain, 34/46 ratio Fuel Economy
Fuel Economy6 32 mpg 7.35 l/100km Fuel Economy6 47 mpg 5.0043 l/100km
Gear Ratio (overall)
1st 9.593 9.593 2nd 6.65 6.65 3rd 4.938 4.938 4th 4 4 5th 3.407 3.407 6th 2.875 2.875
WHEELS/TIRES
Wheels
Front7 Roulette Roulette Wheel Option N/A N/A Rear7 Roulette Roulette
Tire Size
Front 130/80B17 65H 130/80B17 65H Rear 180/65B16 81H 180/65B16 81H
ELECTRICAL
Instruments N/A N/A Indicator Lamps8 High beam, neutral, running lights, turn signals, low oil pressure, engine diagnostics, cruise control, speakers, accessory, security system, 6-speed, low fuel warning, ABS. High beam, neutral, running lights, turn signals, low oil pressure, engine diagnostics, cruise control, speakers, accessory, security system, 6-speed, low fuel warning, ABS. Reverse Function N/A N/A
CHASSIS
Brakes 32 mm, 4-piston fixed front and rear 32 mm, 4-piston fixed front and rear Parking Brake N/A N/A Lean Angle 33 ° 33 ° Exhaust System Chrome, dual exhaust with 4in. touring mufflers, chrome billet end caps and touring muffler shields Chrome, dual exhaust with 4in. touring mufflers, chrome billet end caps and touring muffler shields
COLOR OPTIONS
Color Options Scarlet Read Pearl/ Dark Slate w/Flame graphic
Riptide Blue/Titanium Dust w/Flame graphic
Burnt Amber/Hot Citrus w/Flame graphic Scarlet Read Pearl/ Dark Slate w/Flame graphic
MSRP starting at $35,999
PRICING1
MSRP
Vivid Black$35,999ColorN/ATwo-ToneN/ACustom ColorN/A
SecurityN/AWheel OptionN/AABS OptionN/AReverse OptionN/ACruise Control N/ACalifornia Emissions $200Freight$380
Luggage Capacity
POWERTRAIN
WHEELS/TIRES
Wheels
Tire Size
ELECTRICAL
CHASSIS
COLOR OPTIONS
PRICING1
MSRP
- 1 Prices listed are the Manufacturer’s Suggested Retail Prices. Options such as color are available at additional cost. Prices exclude dealer setup, taxes, title and licensing and are subject to change. Dealer prices may vary.
- 2 Measurement reflects 180 lb. (81.7 kg) operator weight.
- 3 Recommended 91 octane or higher fuel (R+M)/2.
- 4 Values shown are nominal. Performance may vary by country and region.
- 5 Standard and optional fuel systems may vary by country and region.
- 6 Estimated from fuel economy tests on a sample motorcycle from the corresponding family conducted by Harley-Davidson under ideal laboratory conditions. Not all motorcycle models undergo fuel economy testing. Fuel economy and mileage may vary among motorcycle models within a family. Your mileage may vary depending on your personal riding habits, weather conditions, trip length, vehicle condition and vehicle configuration and other conditions. Break-in mileage may vary.
- 7 Standard and optional wheels may vary by country and region.
- 8 North America security system includes immobilizer; outside North America the security system includes immobilizer and siren.
I don't really care for flames(it's just not me - wife also). But when we saw that color combo and it has the flames, we both agreed it was nice and we'd like to have it.
From my understanding while talking to my dealer yesterday, they (MoCo) is now only making the new mid year color which is the part of the "dark-side" color scheme. The black & gray color scheme has black chrome instead of chrome & comes w/ a zumo 660 gps mounted to the fairing. Along w/ a $500.00 up charge for the goods. They are no longer making any of the orginial colors from back in August. I could be wrong but that what I was told at the dealer. Either way, I do like the look of the new black & gray cvo ultra & if money is no object, go for it and enjoy the ride!
cdestuck
01-21-2010 04:06 PM
