HP&TQ Of the CVO 110
Old 01-31-2010 | 10:42 PM
dkatko's Avatar
dkatko
2nd Gear
Default 09 SECU Rinehart slipons and dyno
Looking forward to spring.
  #32
Old 02-14-2010 | 07:21 AM
madurodave's Avatar
madurodave
Looks like the 110's are all in similar ranges. I will post mine later.
Ended up with 97 hp and 120 tq and very nice curves.
  #33
Old 04-12-2010 | 09:09 AM
EasyriderFI's Avatar
EasyriderFI
Default I can only dream
Originally Posted by screamin 110
Well I have an update on my FXDSE2
Ported heads (moto headz racing)
11-1 compression
Woods 408-6
HPI 58 TB
full roller valve train and adj push rods
RB Racing Challange 2 into 1
It pulled 130.1 hp and 139.9 tq
Man this thing rips now. I cant wait for summer!
Nice numbers. I can only wonder and dream about what that feels like.
  #34
Old 04-24-2010 | 10:33 AM
Vettepro's Avatar
Vettepro
11-1 compression
Woods 408-6
HPI 58 TB
Nice numbers!!
  #35
Old 05-01-2010 | 03:53 AM
toofast_28's Avatar
toofast_28
6th Gear
2007 FXDSE, V&H big radius, SERT. 94 HP, 113 TQ
  #36
Old 05-01-2010 | 07:35 PM
mps1168's Avatar
mps1168
07 Ultra, 103, Andrews 54H cams SERT/wTTS Mastertune, SE Slip ons, factory header.
Tuned by Jamie at FuelMoto 90hp/103tq
  #37
Old 05-05-2010 | 06:49 PM
Jason Hedrick's Avatar
Jason Hedrick
Mine's a 2010 FLHXSE w/ V&H cross head pipes,V&H monster slip ons and SERT-hot off the dyno today- Max Torque 109.36, Max power 95.43
  #38
Old 05-17-2010 | 11:58 PM
STSSE-PA's Avatar
STSSE-PA
4th Gear
Sorry I'm late,
Gentlemen, it really does't matter what the HP or Torq readings are, if you haven't got the mileage on the clock to have broken in the engine.
How many of you have a 6th gear that barely holds unless you are doing 65mph? Exactly my point! You don't have the K's to allow it to work for you.
Bob the Oil guy another blog says it takes a min of 10K to break in a big V-Twin on syn oil. If you have changed the oil @2500, not 5K you can probably double that. If you are like some and used Amsoil it will take even longer.
Because of the Warranty implications, I have let the service dept put in the Syn3, and changed it out @2500 later with Amsoil. I am approaching 25K and the engine still seems to be evolving.
Now that I have gotten over the hump, 6th gear will pull a steep hill at 55mph and accelerate.
For what's it's worth......Jack
  #39
Old 05-18-2010 | 08:15 AM
dope_man_21's Avatar
dope_man_21
Originally Posted by STSSE-PA
Sorry I'm late,
6th gear, heck 5th gear is barely usable unless I am running on the interstate
BTW WHO THE HELL IS Bob the Oil guy?
  #40
Old 05-19-2010 | 11:53 PM
STSSE-PA's Avatar
STSSE-PA
4th Gear
got to slow down MC, you're using up to many tires.
sounds like you have less than 5K on the clock. Are you experiencing the chopping action at the rear wheel? early in my relationship with this bike, the rear wheel would bite, slip, bite, slip due to the cylinders firing under acceleration, usually on a wide enough turn. once I got enough miles over 5K, I could drift the rear wheel on gentle bends with no chop.
you will have to dig into the forums to find the V-twin window. Have not been here for a while. You will find oil wear analysis on all kinds of stuff in here.....Jack
PS someone has a complaint against him because he would not let them discuss "BITRON" in depth. I'll look it up and see what I can find out.
http://www.bobistheoilguy.com/forums/ubbthreads.php
Quick Reply: HP&TQ Of the CVO 110
