HP&TQ Of the CVO 110
Sorry for my obvious inaccurate claim
With all due respect there's simply no way that 89 hp can push an SE Ultra to 145. Simply not gonna happen. Physics are irrefutable.
The most that 89hp is gonna push that bike is around 120-155 mph. Its good to hear your bike runs smooth but your claim that it does 145mph makes all your other views suspect.
Here's the dyno from my bone stock 2010 SEUC 110. I had this run graphed in advance of the engine work I had done. Getting dyno tuned in a couple of weeks with the new engine.... 58mm TB, larger injectors, Headwork by Hillside (10.5comp), se roller rockers, adj pushrods, Ventilator A/C, SEST, D&D Boss Fat Cat.
Oh OK. Well it felt like it! lol. When I had 6K on it last March my Garmin 550 recorded that. Dyno numbers are from a Dyno Jet last week. With the new laws in Flordia I won't be repeating that with my 660. I might give it a go when I return from the Hoka Hey run to Alaska this summer if I'm in Montana. I wanted to see how the new frame reacted as even with a true track I couldn't get maxed on an 06 SEUC due to wobble/tank slap above 100. I don't know what the speedo went to, all I know is a few days later I saw the number on the Zumo under Max Speed. Thanks for the Physics explanation. I'll crawl back under a rock and abstain from from further posting my inaccutrate observations.
Not to many people that want to pay for a dyno run before they do any mods. Even the simplest (a tuner, or exhaust) is going to change the numbers a bit from "factory stock". Stock has different meanings to different riders however, I think you meant "factory stock".
I think I saw it posted someplace on CVOHarley forum.
07 cvo ultra dyno numbers
The Dyno Sheet shows my 07 CVO Ultra as stock, and after installation of Ness Big Sucker AC, Rhinehart True Duals, and PCIII-USB. Before: Torque = 96.1 @ 3700 RPM, HP = 72.9 @ 4500 RPM. After: Torque = 110.5 @ 3500 RPM, HP = 89.5 @ 5500 RPM. I've added a Lehman Trike Kit, so the torque curve with the peak torque @ 3500 RPM is a good match to the loading requirements of the 1200 lb trike. I am not interested in shifting the torque curve to the right (higher RPM) to achieve higher HP numbers, but I would like to increase the torque of the present curve. I am not sure whether a 2 into 1 exhaust would give me better torque numbers than what I am getting now?
