Cataleytic converter in an '09 CVO
Old 03-14-2009, 04:21 PM
jamesrgarner's Avatar
jamesrgarner
jamesrgarner is offline
Default Cataleytic converter in an '09 CVO
My dealer told me today that only the CA models have a CC - I think all '09 CVOs do; Who is right?
Old 03-14-2009, 05:28 PM
peppi's Avatar
peppi
peppi is offline
You are, but not the 96 engines, just the larger CVO bikes.
Old 03-14-2009, 08:37 PM
SteveO's Avatar
SteveO
SteveO is offline
All the CVO bikes have them in both pipes. Just punched mine out, has a slightly better sound.
Old 03-14-2009, 09:06 PM
Bigbender's Avatar
Bigbender
Bigbender is offline
I'm not sure about the Fat Bob and Springer but all CVO Road Glide and Ultras have catalytic converters this year. They're no longer in the mufflers though because the EPA wasn't happy that people were able to eliminate them easily by installing slip-ons. The moco now presses them into the header pipes (before the crossover) with a very restrictive steel screen that's 5.5" long.
It's a coincidence that you wrote this today because I just bought a spare header from another CVO owner that decided to buy new 2 into 1 pipes. I spent this afternoon cutting his header in half then chiseling and grinding out the catalytic converter. This pipe had low miles on it and the engine side was just about clogged up already.
Old 03-15-2009, 08:03 AM
jamesrgarner
Was the CC in both pipes or just the right one? I've heard both but in reading the post and seeing the photos posted by Jim it appears that there is only one in the right side. Then again, these are 2-1-2 pipes and the primary pipe is on the right side.
Old 03-15-2009, 10:44 AM
Bigbender's Avatar
Bigbender
It completely fills the collector pipe. People were buying core bits to drill them out but they were only getting the pipe for the back cylinder.
Old 03-15-2009, 06:28 PM
Desert Rat's Avatar
Desert Rat
Desert Rat is offline
If you want to see what the head pipe looks like with the CC, check out the link below. I just swaped out my stock CVO head pipe on my '09 FLTRSE3 with a head pipe from a non CVO '09 bagger, and the gains in HP, TQ, & imporved sound where incredible. If you have an '09 CVO, the power robbing, heat maker of a CC has to go.
D2
http://www.cvoharley.com/smf/index.php?topic=33475.0
Old 03-15-2009, 08:38 PM
jamesrgarner
D2
How much did the new header pipes set you back? I think that's the way I need to go; then replace the baffles with a set from Fullsac.
Old 03-15-2009, 10:21 PM
Desert Rat's Avatar
Desert Rat
JG,
Got mine for $150. I worked with my dealer and asked him to give me a call when a non-
cvo touring model came in for an exhaust upgrade to save me the head pipes if the customer did not want them. Took about 6 weeks for this to happen. Normally a new set of head pipes cost ~ $400. Definately the way to go.
D2
Old 03-16-2009, 08:36 PM
fishafly's Avatar
fishafly
fishafly is offline
Those pics by Desert Rat are unbelievable! I can't believe there is that much CR^P in those pipes... Crazy!
Quick Reply: Cataleytic converter in an '09 CVO
