I should not of bragged
Old 11-15-2008 | 09:58 AM
dope_man_21's Avatar
dope_man_21
Angry I should not of bragged
I was posting the other day that my bike had not had to have any repairs, and now as I was riding home from work this morning it just quit accelerating, well made it home checked the bike out and found that the idle cable was broken, causing the throttle to return past zero position. No body around here has these parts, Had to order them from Oregon and have them shipped PDQ, it is going to be a long couple of days.
Old 11-15-2008 | 10:22 AM
rbabos's Avatar
rbabos
There are several things wrong with your setup in the first place. The return cable should not even see much action pressure wise and if it breaks there were some serious adjustment issues. You can't go past 0 as the tb has a stop as well as the grip inside has a stop. These two should almost touch the same time with tb stop slightly before the grip stop. The return cable is then adjusted to take up it's slack and no more, or you will place both cables under pressure, all the time. By placing the tb stop and grip stop at almost the same time the return cable sees no stress and won't fail. Incorrect adjustment of this cable will also result in failing to go full throttle as well. For what it's worth either the factory or dealer in my case don't have a fkg clue how to adjust them either as my bike would only go to 3/4 throttle when I got it.
Ron
Old 11-15-2008 | 11:55 PM
dope_man_21
Ron
The throttle body is not retuning past zero postion, it is just the throttle grip itself, causing confusion when I twisted it and noting happened. the cable had broken due to water sitting inside of the cable housing allowing it to rust, I know it is not good, but it happened, as a matter of fact it seems everytime that I ride more than 20 miles I end up getting rained on.
Old 11-16-2008 | 05:09 PM
Fireman44's Avatar
Fireman44
ride only 19 miles
Old 11-16-2008 | 05:18 PM
meepers's Avatar
meepers
Originally Posted by Fireman44
ride only 19 miles
hehehe...
Well, your FIRST problem, as your topic shows, is to say something silly like ** ooh I have no problems**
I run into the same thing when I throw stuff away, I am a pack rat, I will horde stuff for like 5 years, I will chuck it, and need it the following week.
Just be happy it was your throttle cable, I was coming home one night, going to make a left at a stop light and my CLUTCH cable broke, thankfully there were no cars coming at that very second.. it could have gotten really ugly. Worst part about that, it was my fault for routing the cable wrong and had no one to blame.
Old 11-16-2008 | 09:19 PM
dope_man_21
Talking
ride only 19 miles
This is a good ideal but however it is impossible, I live at least 20 miles from anything...lol
Old 11-17-2008 | 12:38 AM
skyhook's Avatar
skyhook
that's a pretty bike...mine's dirty and bobbed to 650 lbs...sorry about your problem, hope ya get it fixed soon
zachpeed
03-03-2014 09:50 AM
top0211
11-08-2012 06:41 PM
bigdano
09-02-2011 10:35 AM
firemantom
07-12-2008 09:51 AM
masterblaster
06-25-2007 03:07 PM
