FXDSE2 Upgrade 110 Engine...Problem
My 2008 FXDSE2 with a little over 2,000 miles on it just had its UPGRADE... I take care of my baby, only put in High Testosterone at the gas pump but about 100 miles ago I saw the first sign of the dreaded oil leak. By coincidence that day my Harley Dealer called and told me they had the kit in to UPGRADE my ride so in it went on last Saturday afternoon.
Got the bike back Thursday afternoon, rode it home and it just did not seem to have the same punch that it had before. I thought that maybe it was my imagination since they told me they would not have to put it on the Dyno for this upgrade...sounded sane to me. As I put the bike through the gears, even the sound was not quite the same and when I brought her into the red zone she backfired...everytime. In addition, I could hear a tappet-like sound which was never there before.
Other than the obvious that it needs to be retuned ...probably going to cost me $160...any comments or suggestions? Should I just ride it for 300-400 miles and see if she settles in or should I bring her back asap?
Jim (FXDSE2)
Jim (FXDSE2)
picked up the FXDSE2 this morning and I followed the suggestions made by SKYHOOK above and the bike is back to perfect running condition.
I brought it up to 6,000 rpm...after that it cuts out so it never gets above 6,000. The HD Dealer said to use the engine and that it is broken in and should be used up to the red line...6,000. Is there a problem with this? FXDSE2
I'm confused also. I read where you had put 2,000 miles on it before the oil leak and the bike ran good. Then you brought it in to fix the oil leak and now it doesn't run as well. What would the oil leak fix have to do with the tune of your bike? Did they do some type of flash to your ECM? Maybe they didn't tighten a connection properly?
I would think it is something simple and hopefully they will be able to correct it asap.
Good luck,
Tom
Good luck,
Tom
Fx...no problem at all. Your bike, do with it what you want but I've had motors rebuilt and had to break them in, as in not take them to redline for a period of miles usually 500-1000. I remember the tech saying that the rings need to seat and such. It's essentially a new motor and when that motor was new, there was a break in period of 500 miles so why not after adding new pistons, rings, jugs,etc. I was just passing along more of a question than a derogatory statement.
