it says right in the description will not work on cvo’s
I did not buy it from them but its the same no matter where you get it from. None the less it was sold to me as if it would work if I unplugged the whim.
Roger that, there is supposedly a flash that will fix the problem on cvo’s or any bikes with radios flashed for a whim
Im going to check with the dealer and local stereo shop. I found a guy off youtube ( Carlos at NVS audio ) who can do it but he is in NJ so i would need to pull my radio out and ship it to him.
All CVO bikes come flashed for WHIM from Factory. You can try getting dealer to disable WHIM and then try the adaptor. That's the only difference between CVO and non-CVO touring bikes.
