Thoughts on the Memphis Shades Hand guards?
Old 10-10-2019 | 08:53 AM
Magnut1's Avatar
Magnut1
I have a RK with heated grips, I guess that would be even better. Gotta check it out. I can paint them Starlight black metallic to match my paint.
Old 10-29-2019 | 12:19 AM
flash1034's Avatar
flash1034
If you’re asking for opinions....I hate em.
Old 12-15-2019 | 06:19 AM
Fatboy16S's Avatar
Fatboy16S
I ordered a set on Black Friday for my FBS and think the quality and look of the gaurd itself are excellent. However, the brackets supplied would bring my review from a 5 down to a 1. The brackets themselves are very nice aluminum and have a durable coating. The bad is the design of how they fit. My FBS has the turn signals on the bars so I had to get the ones with cut outs for the lights. The way they attach is with two different angle brackets which are a short and a long one. The bracket mounts between the stem base with a locking washer which once tightened is supposed to keep the gaurd in place. I think one side would constantly come loose if I were to use the supplied brackets. The cutouts do not line up which has kept me from installing them. I did verify fittment through multiple sellers, so I know that is not the issue. I am going to keep them and make my own mounts using a clamping bracket to the mirror stem which will keep me from having to remove the blinker and mirror everytime I want to add or take them off. The quality of the gaurd is excellent and I am hoping the protection will help with keeping the wind off of my hands below 35 degrees. Even with heated gloves my fingers get numb.
Old 12-15-2019 | 06:42 AM
mskirwin's Avatar
mskirwin
Hope they help. Might try a set on my ride.
Old 12-17-2019 | 08:41 AM
CaffeineBuzz's Avatar
CaffeineBuzz
not a fan of the looks
Old 12-20-2019 | 09:40 AM
67Shuv's Avatar
67Shuv
Veteran: Marine Corp
I’ve got the same 12” PY bars on my street glide and have been considering hand guards for the winter time. Probably pick up some el-cheapos from amazon to try out.
Kennypatterson
07-17-2020 09:07 AM
ssrgeoff
Touring Parts
12-15-2019 06:11 AM
milleda31
2014-2023 Touring Models
87
11-16-2015 01:32 PM
Wolfman
06-06-2015 11:36 AM
Quick Reply: Thoughts on the Memphis Shades Hand guards?
