Help! 2014 CVO Ultra Limited wont start
The battery is good, volts good. Everything powers up. Fuses good. Fuel pump engages. Keys good, with new batteries. Hit the start button, nothing. No codes. Starter not engaging at all. Will not start in neutral or any gear, clutch in or out. Quiet as a mouse, no solenoid clicking. I'm thinking about some kind of sensor. Any ideas?
Yes, you should hear a click then the fuel pump priming. One thing I had to do a couple of times, Take your Fob and put it 20 feet away. Walk back to the bike. Turn ign switch on, and run switch on, then go get your FOB and bring it to the bike. Look to see if the security recognizes the fob. if it does, Now try the starter switch.
Lex_Talionis
11-22-2011 09:10 PM
