110 to 117
Old 09-20-2018, 09:47 AM
SilverEagle50's Avatar
SilverEagle50
SilverEagle50 is offline
you're really not comparing apples to apples here when talking about changing the twin cam 110 to a 117 and then comparing it to the M8 117.
you have the same cubic inches, but the M8 is a different motor than the twin cam. In a discussion with Fuel Moto about upgrades to my 110 (have already done their 110 upgrade), I was told I would be better off buying a new M8 bike to get the best numbers.
oldmanwayne (09-21-2018)
Old 09-21-2018, 05:59 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
We have built a customer favorite 117" for many, many years now.
Our HMM Stage II CVO Heads
S&S 4 1/8" bore cylinder kit
Wood 9F cams
58mm t/body
D&D Borezilla.
Those will produce 135-140 hp and 140 ft/lbs....on a bad day.
Broad-band torque, great reliable, pump-gas fun.
Scott
The following 3 users liked this post by Hillsidecycle.com:
oldmanwayne (09-21-2018), SilverEagle50 (09-21-2018), vpnwiz (09-25-2018)
Old 09-21-2018, 11:02 AM
groupw's Avatar
groupw
groupw is offline
Originally Posted by 30glock
What is a reasonable price from HD to do this work ?
...... i've seen HD shop invoices for a 117 kit at just over $5k, incl. SE tuner
Old 09-21-2018, 11:04 AM
donk_316's Avatar
donk_316
donk_316 is offline
Wood 9F cams
58mm t/body
D&D Borezilla.
Scott
Holy crap that would be a rocket ship. Is there a dyno sheet floating around for that? Just curious more than anything else. I really need to dyno my bike to see what I'm at.
Old 09-21-2018, 01:15 PM
Magnut1's Avatar
Magnut1
Magnut1 is offline
Received 1,725 Likes on 844 Posts
Just my 2 cents worth. Seems like everyone thinks you have to install hi flow injectors and 58 mm TB on every build. I am researching installing a stage 4 kit and talking to zippers and moto,, they both say unless you are planning on 125 + HP, you can stay with stock injectors and TB. So you can save a few bucks there.
Now having said that, I believe if your build is 120 HP, you could get a few ponys with the hi flow and 55 mm TB but that is if you have lots of $$ or trying to budget and not have to buy a new AC..
oldmanwayne (09-23-2018)
bikerchronicles
Milwaukee Eight (M8)
29
04-25-2019 04:04 PM
bigdog1949
Audio Systems
02-24-2019 10:33 AM
elb62
Engine Mechanical Topics
05-09-2016 01:27 PM
Aggressor05
Screamin Eagle CVO Models
02-23-2016 11:15 AM
plongson
2014-2023 Touring Models
17
07-05-2015 07:00 PM
Quick Reply: 110 to 117
