Why no Stage 2 Torque cam for 117?
Local dealer is wrong. The cam in the 117 CVO engine is unique to it. Not in any other engine. Andrews cams did a profile of it, and got the specs because Harley is not releasing them.
See above, not the torque cam. Its only in the 117 CVO.
Attached are the cam specs for the 117 CVO engine.
I do believe it is why there is no torque cam for the 117, or a tune.
GMR has done a really nice cam for the factory 117.
Cruisin1966 (08-25-2018)
I'd be really interested to hear what map they actually used if they installed a torque cam in your 117. I'd also be interested in seeing the dyno chart. I have yet to see any dyno charts and numbers for HD stage 2 setups on a 117(other than aftermarket).
I have an 18 117 CVO Limited and was trying to get information from my local dealer as well. After a mix of information I called HD customer service. They confirmed that the only stage 2 cam for the 18 CVO 117 is the "power" cam, which matches what I can see in the Street tuner software. It only shows a map for the Power cam configuration.
