Installation Chrome Starter Solenoid Cover
Okay, so today I bought the chrome starter solenoid cover. Easy upgrade, or so I thought...
After getting the bolts out (covered in wrinkle paint), I tried to pull the factory cover off only to realize that the factory cover has been encased in wrinkle paint and fused to the starter.
This is ridiculous!
I thought about using a razor blade to cut through it, but it is several millimeters thick and then I could maybe only get two sides of it. Then I would be forced to twist or slowly bend it off and I know that it will cause the paint to flake off the starter.
How am I supposed to get the old one off without breaking the seal and having all the wrinkle coating flake off the starter?
Has anyone else had this issue?
This is ridiculous!
RE: Installation Chrome Starter Solenoid Cover
I have an 01 RKC and added the chrome cover a couple of weeks ago. The factory cover was a little tightbut I gave it a little help with a flat head screw driver edge, taped over the end to keep from scratching, it came right off and I didn't notice any chipping on the body of the starter. Hope that helps.
Good luck.
Good luck.
Branded 1
05-02-2010 06:45 PM
af, button, chrome, cover, good, harley, instalation, installation, push, put, shovelhead, solenoid, solinoid, starter, upgrade
