2017 CVO Rear Shocks
Are the rear shocks on a 17 CVO Limited the same shock that comes on the 17 SGS but an inch longer? I thought the CVOs have a different suspension? I would like to drop the back 1" but I want to maintain the ride quality. The dealer said all of the low profile shocks are the same for 17 CVO or non CVO.
I believe your dealer is correct. If you are wanting to lower the bike because you are like me "vertically challenged" then I suggest a different pair of boots with taller heels because you will sacrifice your ride quality.
I had lowerd shocks on my 09 Ultra took them off after a couple months, they would bottom out too much especially riding 2 up with them being pumped up to 50 psi
________________________
2017 CVO Limited
2017 CVO Limited
