2015 CVO Limited Seat
I put a 2015 CVO Limited seat on my 2015 Limited for comfort and heat. Can any of you 2014-16 CVO Limited owners tell me if the passenger seat takes a while to break-in? First ride with my wife on the back was uncomfortable for her. Hope it just needs some breaking in.
Does the heat stay on as long as the switch is on or does it turn off at a certain temperature? The rear seat seemed to have shut off but I may have hit that switch with my gloved hand and not realized it. Thanks for the input.
Heated Seat
Top of page
Switch Controls
See Heated Seat Switches. The heated seat controls for the rider (1) and passenger (2) are three position rocker switches.
High Heat: Rock the switch at the top for high heat.
OFF: The OFF position is in the middle.
Low Heat: Rock the switch at the bottom for low heat.
NOTE:
Allow 8 to 10 minutes for the seat to warm up.
Automatic Shut-Off
For safety, the heated seat is designed to shut-off automatically after one hour of continuous use. The seat can be turned back on immediately after auto shut-off has accrued with no harm to the system. To reactivate the heated seat the seat switch must be turned OFF and then switched back to the desired setting.
Top of page
Switch Controls
NOTE:
Automatic Shut-Off
Heated Seat
Top of page
Switch Controls
NOTE:
Automatic Shut-Off
Top of page
Switch Controls
NOTE:
Automatic Shut-Off
