2005 FLHTCUSE2 would you buy?
Old 04-21-2015, 12:31 PM
jon69olds's Avatar
jon69olds
jon69olds is offline
Default 2005 FLHTCUSE2 would you buy?
Hi guys,
Looking at getting back into a motorcycle after a 2 year absence. I found this '05 SE Ultra for $18,500 out the door.
http://www.cyclewarehouseonline.com/...387&used=1&vin=
Does that seem like a good deal or not? I'm not sure with it being a SE if it holds more value than a regular Ultra? Is there anything on this year bike that I should look out for? Common problems?
Thanks,
Jon
Old 04-21-2015, 12:45 PM
Hurricane19's Avatar
Hurricane19
Hurricane19 is offline
That sounds about right pricewise if you can like the yellow. 22xxx miles isn't bad for a 2005 and yes the cvo's hold there value pretty well.
Old 04-21-2015, 01:41 PM
jon69olds's Avatar
jon69olds
Actually at first I didn't like it, but after looking at it and thinking "How many yellow Harleys' are there out there?" It's growing on me. Most likely wouldn't see a ton of them on the road either. They had a '07 Ultra (Non SE) as well for $15k, but I figured by the time I was done changing things I'd probably have that extra coin and then some and not have a SE. So we will see. After an '08 Anniversary Road King Classic this should be a nice step up in the bike department.
Old 04-21-2015, 01:47 PM
Hurricane19
Yeah I think I would go with SE over the 07 Ultra, a lot more goodies on the SE and the bigger engine. Does the SE have a 5 or 6 speed?
Old 04-21-2015, 02:17 PM
jon69olds's Avatar
jon69olds
I believe this one still has a 5 speed being an '05, but I could be wrong.
Old 04-21-2015, 02:21 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,822 Likes on 3,174 Posts
5 speed and a 95" Stage II motor, S/E 203 cams standard from the Factory .(Not the best crank shaft set up (vs '99 - '02) but still a pretty good motor IMO.
(I'd take it over a 96" '07 motor in a heartbeat.)
Old 04-21-2015, 02:51 PM
ramblin5's Avatar
ramblin5
ramblin5 is offline
With all the Rushmore changes I would spend a few thousand extra and get a '14 or '15 stock Ultra.
Old 04-21-2015, 04:31 PM
bettingpython's Avatar
bettingpython
bettingpython is offline
If you like it go for it, a friend of mine sold his 05 CVO last fall for about the same price.
He currently has a 2013 Anniversary edition CVO Ultra and a 14 CVO RK, he wont own anything but the best and I admit, they are pretty nice.
The heart want's what the heart want's and making a stocker look as good as a CVO is pricey. Normally I would agree with you but we paid more for a 2009 fat bob last fall than the new 2015's were when they hit the showroom floor. Momma loves her CVO and I must admit they are stunning machines.
Old 04-22-2015, 06:17 AM
kojak's Avatar
kojak
kojak is offline
Received 2,808 Likes on 1,362 Posts
Originally Posted by jon69olds
Hi guys,
Thanks,
Jon
This was one of the most sought after cvo's in its day. 22k miles means its been ridden about 2-3k miles a year, which is nothing. Worth taking a look at for sure. 18k is not bad. The 2015 version would set you back over $42k out the door.
Old 04-22-2015, 07:20 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
09 YELLOWBIRD is offline
I totally agree!
Those CVO 103's of years past would blow the pants off any of the new stock 103" motors of present!
@OP- go for it, the YELLOW CVO's are really the fastest colors. Don't ask me how I know this.
YB
Quick Reply: 2005 FLHTCUSE2 would you buy?
