Rush 2:1 Full Systems
RUSH 2:1 FULL SYSTEMS
· Dyno Tested- Significant increases in low and mid range torque as well as top end horsepower.
· Available in show-quality Chrome or Black High-Temp double baked powder coating.
· Head pipes are ceramic coated on both the inside and outside of the head pipes; improving exhaust flow and reducing ambient heat up 300°. Lower pipe temperatures are more comfortable for the rider and passenger.
· Heavy-duty, 16 gauge steel, which has 30% more steel than the 18 gauge used by other manufacturers. Thicker steel means longer life and better sound.
· Includes full coverage heat shields to cover the head pipes and collector.
· A spiral, louver-packed baffle contributes to the sound and additional power
· Includes a brilliant chromed end cap, constructed of aircraft grade billet aluminum.
· All mounting hardware is included
· 1-year Manufacturer’s Warranty
· 100% Made in the USA
'09 - '12
2:1 Performance Full System
Baffles Available = 200", 225", 250"
8050= '09 - '12 w/02 Bung / MSRP - $629.95
8051 = ’86-‘08
'09 - '12
8150= '09 - '12 w/02 Bung / MSRP - $649.95
8151 = '07 - '08
2:1 Touring Full Systems '09 - '12
For a balanced look try our False Pipe Kit
Comes standard with 3522-R1L Tip
Chrome: 8050FPKIT / MSRP - $289.95
Black: 8150FPKIT / MSRP - $314.95
Performance 3 Stepped 2:1
Baffles Available = 2.25", 2.50", 3.00"
#8050S = '09 - '12 / MSRP - $799.95
#8050SFPKIT / MSRP - $304.95
2:1 Full System '86 - '12
( Does Not Fit '10 - '11 Softail Convertible )
Baffles Available 2.00", 2.25", 2.50" w/02 Bung
#8020 - w/3522-R1R Tip Included / MSRP - $629.95
( Does Not Fit '10 - '12 Softail Convertible )
#8120 - w/3522-R1R Tip Included / MSRP - $649.95
Dyna Models
2:1 Full System '06 - '12
#8030 - w/3522-R1R Tip Included / MSRP - $629.95
2:1 Full System '91 - '05
#8031 - w/3522-R1R Tip Included / MSRP - $629.95
#8130 - w/3522-R1R Tip Included / MSRP - $649.95
#8131 - w/3522-R1R Tip Included / MSRP - $649.95
#8140 - w/3522-R1R Tip Included / MSRP - $649.95
'09 - '12
8051 = ’86-‘08
'09 - '12
8151 = '07 - '08
Dyna Models
#8040 - w/3522-R1R Tip Included / MSRP - $629.95
I like the #8030 for my 08 FXDC but have a concern about mounting.
Because the front exhaust mounting bracket (three bolts under engine) hit my forward brake rod I had to remove it. So, is that bracket used with the #8030 system?
Do you have installation instructions available?
Lastly, are you offering any HDFourm discount?
We supply a mounting bracket that is installed in the same location as the stock one (three bolts under engine).
We do not have any current specials for HDForum members but there are Rush dealers that sponsor the forum and offer very competitive pricing.
-Ryan
Here is a link to our instructions. http://www.rushracingproducts.com/instructions.html
-Ryan
-Ryan
