Question, Can I put rush mufflers from 86 through 94 harley touring on my 2007 FLHX? If no what is the difference in the 86 through 94 and the 95 through 10 rush mufflers?
Street G, the 86-94 slip-on mufflers are a little longer. The inlet of the old style is 3/4" longer. They will mount on your 2007 but there will be a gap between the headpipe heatshield and the muffler shell. Also, if you upgrade your headpipes to true duals or something else they will not fit. You will have to use the 95-10 series if you want to eliminate the heatshield gap or change head pipes.
Thanks for contacting us.
Ryan
