Question
Question
I installed 1.75" Rush Baloney cut Slip On's on my 09 Fat Bob. I have a lot of decel popping. HD dealer where I bought them said that I have to change over to stage one and remapping. Dealer #2 stated they sound normal. Rush slip on's just sound that way. Maybe a pair of Torque cones will help but no quarantee.
Who is right?
Paul
Who is right?
Paul
Who is right?
Paul
Who is right?
Paul
Your situation does not sound typical since you have 1.75" mufflers and I assume the stock air cleaner. If my assumtion is correct the most obvious cause besides tuning would be an exhaust leak where the slip-on muffler meets the head pipe. We use a thicker ga steel then stock mufflers and most other manufacturers, this means you have to torque the muffler clamp to at least 65 ft/lbs (don't go much farther or the clamp will break and always use new clamps.) One way to check this seal is to place the bike outside on a sunny day, look down the inside of the muffler from the back, and if you see any light there is not a good seal at the headpipe.
Decel popping is not typical of our mufflers.
If you need more information please contact our tech department.
Thanks,
Ryan
