Accuracy of GPS units around BRP area.
Gps & brp
All of the civilian GPS units are good to within 3 meters or about 9 feet. You just have to be able to get a fix to know exactly where you are. The BRP has lots of open areas and lots of overhanging trees in other areas. That said, my GPS will show my position even when it loses it's 3D fix. What that means is it doesn't hook on enough satellites to give a perfect fix but seems to be able to keep up with my speed and position on the moving map.
I think most units will be able to keep your position pretty well. I have used mine on part of the parkway and didn't have any gliches.
The challenge that I see with the Garmin (and perhaps other) GPS units on the BRP is a lack of detail on the base map. The map shows almost all of the crossroads, but in general you are traveling on a roadway that has little around it other than forest and very rural areas, so "points of interest" are minimal.
But still, the GPS is valuable in tracking your progress on a road like that, and towns that are near the roadway show up well.
I have had the Zumo 550 for about three years or so. The newer Zumo 660/665 models can be had for close to the same price and are improved significantly.
Mine works fine in that area. I have a Zumo 550 as well.
I know it seems hard to justify to spend the extra money to get a gps designed for a motorcycle, but I think it's worth every extra penny.
Shock resistant, water resistant, much more secure mounting bracket and able to use them with gloves on.
Dennis
Dennis
Rode the BRP recently, my Garmin Nuvi 255 worked fine. I'm one of those cheapos who have not been able to justify the extra cost. I'm never had any problems with vibration, and if rain starts I just slip a ziplock bag over the unit. As for a secure mount, I don't think there's much better than the Ram mount.
Bigger issue for me was ATT's lack of service in the mountains! If I'd had a problem that required me to call for help, I would have had to flag down someone else and ask to call on their phone.
I agree, but rams mounts can be used on any model of gps. How the unit attaches to the ram mount is what is very different.
I am not saying the cheaper auto versions won't work and work well. I used a 130 street pilot before the zumo 550.
Just saying there are advantages. What they are worth is just an opinion.
Dennis
Dennis
Just did the BRP the entire length with a Nuvi 755T. I did see a couple of spots where according to the GPS I was riding on grass. They are great on that road for determining the closest fuel. I also like to be able to switch it to show elevation which was normally within 10-20 feet of the posted elevations. Also great to show you how sharp the next turn in the road is. I fiind in NC they will post the speed limit at 55 and never warn you that you can't take the next turn over 35 and stay on the road. Got back on the drive from a side trip from fuel and was good to see the GPS telling me is was heading north when I should have been heading south. I like to be able to plot the roads I want to ride, download to the GPS and then just sit back and enjoy the ride. I wouoldn't want to travel without one.
