Help planning 3 days around the "Dragon"
I feel lucky to have "discovered' this area two years ago and I've been going once in the spring and then again in the fall. Pittsburgh has long winters and this is a great way to kick off and end summer. There are a lot of great posts with suggestions. What really made my trips great was the maps from americaridesmaps.com which will give you great rides you may not know exist.
http://www.americaridesmaps.com/Catalogue.htm
Folks have already covered some good road choices, so I'll chime in with something else. I wouldn't let a Holiday Inn drive my choice of location, as Murphy ain't that convenient for the roads listed above...unless you do wanna hit north GA too. If you're concentrating on the Dragon, Cherohala, the Smokies, BRP, Cherokee, etc., then Murphy wouldn't be my choice. You would be much better off somewhere like the Ironhorse. http://www.ironhorsenc.com/ There, or some other place around Robbinsville, NC, would put ya smack dab in the middle of it, giving you a lot more ride options IMO.
