Northeast trip this summer: Need advice
This is all really great info. I am going to have to look up some of this stuff on Google (Kancamagus Hwy?) and try to plan it in to our trip. I never thought about the Laconia Bike Week. If we go at that time of the summer I will try to work that in to our trip. Once I let all this info filter through that gray matter in my head, I am going to set down at the computer and use the ride planner to map it out. Keep the suggestions coming. I really do appreciate it. Thanks again.
Next time up that way I'm going to try to take my time and avoid the Interstates, especially 95. Rt 7 looks interesting but has anyone tried Rt. 22 which parallels it on the NY side all the way up to Burl. Vt. Reason I ask is that it's listed as a "scenic route".
I'm definitely going to give it a shot next trip to Americade.
Off the Blue Ridge Parkway, take the Skyline Drive up to Front Royal, Va. From there, work your on Rt 81 until you pick up Rt 15 North...take that to Rt 14, then into the upstate New York/five fingers area. Then work your way thru the Adirondack mountains into VT. Pick up Rt 2, which will take you across NH and into Maine...(Bar Harbor). Pick up the ferry to NS. Once you're done with the Cabot Trail (counter clockwise recommended), then work you're way back into Maine via Rt 1. This is THE way to go and avoid traffic. I would be going in July if I had a choice. May is void of tourist, but the weather can be problematic.
I was going to try to pick up the ferry to NS but I called to inquire about rates and they told me that the runs from Bar Harbor and Portland were being discontinued. The lady said that there is a chance this may not happen but as of right now those runs will not be available this summer. Too bad. I really wanted to go in to Nova Scotia but I don't think I would have the time to ride that far around the channel.
We are going to ride from Maine to Ohio this summer so will be looking for directions that way. Definitely want to avoid as many major cities and highways as possible.
Thanks
We've decided to reverse our trip by traveling up the coastline to Maine and return home through VT, NH, NY and PA. Our intention is to stay on 1 or 1A as much as possible for the trip north. I think NJ is the only place Rt 1 does not follow the coast and we will leave it to follow the coast. We are going to drive up Long Island and take the Orient Point Ferry to New London, CT where we will again pick up Rt 1 to go through Boston and head up to Bar Harbor. Any construction to be aware of if I follow this route?
Thanks
Thanks
your best bet would to be pick up rt 1 north of boston in topfield. form there it will take you right into nh and maine.
