Tire Plug kit and small compressor
Old 06-14-2019 | 11:16 AM
Nokkon Wud's Avatar
Nokkon Wud
Originally Posted by MyFavRk
I've been carrying a small Slime air compressor with a built in pressure gauge . Only had to use it once . I bought a tire repair kit with plugs and tools to do the job , but after seeing the Stop and Go mushroom plug kit , I will going shopping to see if I can find one before I head out on my trip . It looks so much easier to use and the mushrooms look as thought they would do a better job at plugging the hole instead of the " rope " which can get pretty messy during install .
Gotta love this forum !
Were you happy with the slime comp? That's what I carry but have never used it.
I also ordered the mushroom kit because of this thread.
Old 06-16-2019 | 08:13 AM
MyFavRk's Avatar
MyFavRk
Sorry I'm late with this , yes , I love this pump . It didn't take very long , about 10-15 min to fill the tire from flat . It was easy to hook up the doohickey thingy to the valve stem , but I think I will be picking up the extender just to make it easier . I've never used the slime itself , just threw it out when I bought the unit . I bought the mushroom kit the other day , pretty expensive little gizmo , but for the ease of repair , i think it's worth it . One thing I learned is that you should run the pump every once in awhile to make sure it's not seized and to keep the seals from drying out , not sure how true this is , but I do it every spring , then I know it'll work when I need it .
Old 06-16-2019 | 09:01 AM
MajorKG's Avatar
MajorKG
Old 06-16-2019 | 01:22 PM
crackerbiker's Avatar
crackerbiker
Used plug and mini-compressor on trip to Alaska. Takes about 5 minutes to pump 15 to 20 pounds. Definitely recommend both, not CO 2 cartridges.
Old 06-17-2019 | 09:13 AM
Nokkon Wud's Avatar
Nokkon Wud
Thanks, going to run mine this afternoon. I also ordered the mushroom kit.
Old 06-19-2019 | 07:57 AM
ghostrunner's Avatar
ghostrunner
I use the Stop and Go kit with the small compressor. Very small has it own bag just throw in saddlebag
Old 06-19-2019 | 11:17 AM
ROCKOUT Rocker Products
Sponsor
Originally Posted by CanadianRocky
A good idea is to intentionally drive a screw into a tire at home just before you install A new one.... the tire is junk anyway.... and then fix it with a plug, and try different pumps & compressors to see what works for you ... the best way to learn is not necessarily up a Logging Road(or on a remote Nevada Highway) , the way I did..... that’s where I had the Co2 canister system fail on me.
That's an awesome tip
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Tx_Rider
06-03-2010 07:27 AM
hotshot
07-26-2009 10:33 AM
Opossum
09-22-2007 10:48 AM
oilhog
06-30-2007 11:52 AM
harleyboy63401
05-26-2005 09:48 AM
Quick Reply: Tire Plug kit and small compressor
